Resource icon
System Command Example In Loadrunner 2017-12-05
No permission to download
Attached is the sample loadrunner file
Example Description
In this example we are doing following activities via a loadrunner script
1. Create a direcotry named speforums in your C drive.
2. Execute a ping command and save it as a file inside c://speforums directory.
Sample code
Code:
    char filename[1024], command[1024];
    //define directory name
    char new_dir[] = "C:\\speforums";
    // Create a directory under root called xyz and make it the current dir
    if (mkdir(new_dir))
        lr_output_message ("Create directory %s failed", new_dir);
    else
        lr_output_message ("Created new directory %s", new_dir);
    //Define a filename
    sprintf(filename, "%s\\%s", new_dir, "pingfile_speforums.txt");
    // Execute a ping command and direct it to a new file
    sprintf(command, "ping speforums.com >> %s", filename);
    system(command);
    lr_output_message ("Created new file %s", filename);
Attached is the working script file.
Final Output:
Contents of the file:
admin
Downloads
0
66
0.00 star(s) 0 ratings
More resources from admin
