Resource icon
Exporting and Importing Runtime Settings in loadrunner
Import and Export Runtime Settings
This topic describes how to import and export runtime settings. This functionality is available for all Vuser protocols.
Importing and Exporting runtime settings can be helpful in many ways to a tester as this has following advantages
  • Saves time by copying simler settings to all scripts.
  • Maintains standardisation across tests
Export runtime settings
  1. Open a script and double-click Runtime Settings in the Solution Explorer.
  2. In the Runtime Settings view, click Export All.
  3. In the Save As dialog box, choose a location for the JSON file that will store the runtime settings and click Save.
Import runtime settings
  2. In the Runtime Settings view, click Import.
  3. In the Open dialog box, select a JSON file containing the runtime settings that you exported earlier and click Open.
  4. Save the script.
admin
416
0.00 star(s) 0 ratings
More resources from admin
