loadrunner Where to place Validation check in loadrunner...
  • Thread starter Rajashekar Chilukamari
Where to place Validation check in loadrunner scripts ? With an example Thank in Advance :)
Test 101: Every step has an expected result, so you should validate that the expected result is received every time you have a new step. Branch your code and exit gracefully when your expected step is not satisfied
