loadrunner When you record Web/HTTP scripts using HP...
Silvia Siqueira
When you record Web/HTTP scripts using HP LoadRunner’s Vugen, you might find that the script won’t play back without modification. This is often due to values that apply specifically to the current session. Because Vugen is playing back values that were recorded when the script was originally recorded, these values are not valid when played back. To make the script play back correctly, these values must be replaced with values from the currently executing session. The process of identifying and replacing these values is known as correlation. Continue reading to learn some tips that will make it easier for you to correlate values in your Vugen scripts.
safe_image.php
