loadrunner what perspectives are observe to select a...
C
Chidvilash Vakada
what perspectives are observe to select a automaction tool(in android app testing)....? can u pls ans
You are probably better off posting this in a forum for HP UFT or some other product that caters to test automation. That said, you can use VUGen to build automated scripts for limited automation of Android apps. Try the TruClient mobile protocol. But there is a saying that I like: "When you are a hammer everything looks like a nail." Use the right tool for the job and you'll be happier.
