admin submitted a new resource:
Throughput/Transactions per Second (TPS) - Defining the key performance measurement quantity of throughput
Read more about this resource...
Throughput
In general terms, throughput is the maximum rate of production or the maximum rate at which something can be processed [Wikipedia]. In real world we define any rate of processing as throughput, for example - Network throughput.
In network communications throughput is defined as the amount of data (bits) transmitted from one system to another per unit time. For networks, throughput can be measured in Kbps, Mbps or Gbps.
In...
