loadrunner please help me Its urgent in hp loadrunner...
  • Thread starter Rajashekar Chilukamari
please help me Its urgent in hp loadrunner 11.52 , where is the tree view option ? thanks in advance
There isn't a tree-view anymore (since 11.50). All the tree-view options are either in the Steps Navigator or the main editor context menu. If you are unable to find a specific option please post what you are looking for here and I will help you.
No need to switch back and forth between tree view and script view to correlate values. Simply add the Step Navigator with the Script View panes and find your values in a single view.
Switch to script view. You'll be happier, will sleep better, have a richer life with your chosen mate, will become taller & your family will celebrate your successes above those of your siblings. ;)
