If I am getting more throughput while load...
  • Thread starter Ankammarao Maddineedi
If I am getting more throughput while load test, is it good or bad....?
Usually the increase in throughput is directly proportional to increase the throughput.
Increase in throughout is directly propotional to increase the response time
The Throughput graph shows the amount of data in bytes that the Vusers received from the server in a second. When we compare this with the transaction response time, we will notice that as throughput decreased, the response time also decreased. Similarly, the peak throughput and highest response time would occur approximately at the same time.
Guys...both should be inversely proportional..Throughput increases response times reduces (Good Response time) ..
