M Meena G Guest May 13, 2016 #1 if correlated value is not captured what may be the problem and how to slove it?
A Aditya Natha Guest May 14, 2016 #2 Your script will fail and will not give correct result. You should use regular expressions to use those dynamic values. Check regular expressions tutorial for jmeter. Upvote 0 Downvote
C Chittabrata Banerjee Guest May 14, 2016 #3 Regular expression problem or you have not correctly added this extractor with the specific samples Upvote 0 Downvote
S Sajal Saha Guest May 14, 2016 #4 Use http cookie manager after doing correlation.....it should be work.. Upvote 0 Downvote
K Koppala Praveen Guest May 23, 2016 #6 R u used debug post processor some times it is also causing for error Upvote 0 Downvote
