loadrunner I am trying to script an application which...
V
Vaibhav Srinivasan
I am trying to script an application which uses planisware. The prerequisites to launch the web application in your client is that it should have a particular Ajax applet or java plugin for planisware. when I try to record, the events are getting captured. I am able to correlate whatever user inputs are keyed in. But then, I am not able to correlate the drop downs which is a part of my business transactions. All the components occur in some octet stream form which is not easily convertible. I tried all possible ways and means to read the pattern in which they are occurring in the response. Couldn't make out. Tried different modes of recording as well. Not working out :( Captured the entire response and tried various conversions. Can someone help please.. Has anyone over here worked in such an application...? Thanks in advance!!!
Ok sure noted... James Pulley, any idea about the above mentioned issue?? :) if you could help, it would be great
I do not provide solutions to shotgun posted questions because this only encourages further abuse. So, where I may have had an answer it is no longer available to you. I see that you are now cross posting this to other forums outside of Facebook. Be warned, you will be banned in some of the forums outside of facebook for this cross post activity. This is destroying the value of all of the communities for people who engage in research on questions
okay thanks. I could see that you are active in all groups/forums. Perhaps someone who is not here but in other forums might have come across the above problem in their experience. I shall share the solution here as well once(and if) I get one in other forums. If you still think that is not recommended, please get this post removed(I assume you are the admin for this group). Thanks for your time, James Pulley
