loadrunner How to run multiple scenarios (using different Controller/LG) in...
  • Thread starter NaveenKumar Namachivayam
N
How to run multiple scenarios (using different Controller/LG) in PC 12? Do we need to create a batch file to trigger scenarios or any other easy way there to accomplish? Thanks!
You schedule them using the scheduler in PC. If you choose to run multiple scenarios at the same time be very wary of shared resources between your two tests. Few things are more frustrating for scenarios two to start only to find and undocumented network dependency that is shared in test by applications one and two which then leads to poor performance for both during the test execution
the problem is i have added 8 scenarios (each scenario has 10 scripts), but only 4 is running successfully. 4 is failing :(
