loadrunner How to handle captcha/text challange in Load Runner?
amitbose
Member
Aug 13, 2014
39
8
8
My application is a using a user creation flow which involves a text challenge (captcha) validation. Is someone aware how to handle such a situation? Can loadrunner use some OCR technique and solve this? any other workaround to load test captcha challenge?
  • Like
Reactions: admin
A CAPTCHA (a backronym for "Completely Automated Public Turing test to tell Computers and Humans Apart") is a type of challenge-response test used in computing to determine whether or not the user is human.
images
images
to bypass CAPTCHA with the load runner or with any other tool , you will have to get one following things from dev/app experts
  • To disable CAPTCHA validation :: Remove the need for it, you can do it easily in any popular CMS, CRM solutions.
  • To make the CAPTCHA as static :: Make sure it sends only same value everytime.
  • To send the CAPTCHA value in server response(So that you can correlate)
  • Provide the CAPTCHA details which are comes in the data base sequentially :: Basically get it from database and make sure it happens sequentially.
