A regular expression is a search string which enables matching of a string. Think of it as an advance searching function where you can pick out values from a string of multiple characters. Examples of regex: • \d matches a single digit • \w matches a single word (including alphanumeric characters and underscore) • [A-Z]+ matches any word which is upper case • [a-z]+ matches any word which is lower case • [0-9]+ matches any numeric value Imagine having a value of “GraphA123567EndGraphA” and the goal is to correlate 123567. Using web_reg_save_param_regexp will allow the user to grab a correlation value using dynamic left and right boundaries. This function uses the power of regular expressions, as the following example: Source: “GraphA123567EndGraphA” Solution: web_reg_save_param_regexp (“ParamName=CorrValue”, “RegExp=\“Graph[A-Za-z]\”, \“([0-9]+)\”, \“EndGraph[A-Za-z]\””, LAST); Result: 123567
