jmeter Hi guys need your help . I am running jmeter webdriver script on...
E
Elad Or
Hi guys need your help . I am running jmeter webdriver script on 10, remote clients but on some clients i get" finished the test on host... " after 1 sec and the script don't execute. What can i do for the script will run in all remotes clients??
When you run the execution on master-slave model, you have to make sure all machines should be in same subnet and firewalls should be disable and master should ping with all slave machines.
