loadrunner Hi guys, I'm doing a demo of Load Runner 12.01...
C
Carlos Garcia
Hi guys, I'm doing a demo of Load Runner 12.01 and I need to integrate with HP Diagnostics,do you know if it is possible the integration with the free version of those softwares ?
I've not done it but given that the only difference in the software is the license key then I cannot imagine why it wouldn't work. I have integrated and used fully licensed HP Diag and LR/PC before many times.
Ok, thanks, But I want to know if the free license is the deal? and Is there a manual which can tell me how can I do it?
Doubt it. Why not just try? What would it cost you since it is just evaluation copies. Actually LR 12 come with most protocols entirely free now.
I've already tried it, but there is not any probe, I don't if is a leak of configuration or I'm doing it wrong or is the the free license
Did you confirm that Diag is working independently? Meaning can you see the probe working locally? There is a config setting for the probe to make sure it works with Diag, TV, standalone, etc... Also does the probe report to the Diag Commander?
