loadrunner Hi Guys, Can any one please help me in...
B
Biswajit Sahu
Hi Guys, Can any one please help me in understanding the difference between Web(HTTP/HTML) and SAP Web Protocol.
James Pulley can you please explain coz while recording I don't not find any difference in the coding part
Sap web protocol is a layer on top of normal HTTP protocol, that recognises the typical SAP web elements. So you will not be able to play back a SAP web script, if you don't have SAP web users in place. Coding it's much the same.
