Hi Guys, Application is running fine but while...
Ankur Tiwari
Hi Guys, Application is running fine but while we recorded a True client scripts and replaying it .. it is dead slow. I googled but could not find specific details. If you anyone of you know then please do share. Thanks.
Why you use true client. It actually runs Firefox. It will be very slow. You might face results affected by tools not application.
client wants response times for specific component over the application. Unfortunately, due to some restriction we cannot use Firefox .. Need to use IE.
Why not http protocol ?.. And , when you run true client, it will run with build in firefox (not that you want or not).. in load runner
And, If for single user scenario.. use true client.. not hundred users with true client.
It is for single user but while replaying it is taking ages
yes.. but I think something needs to be updated in LR or may be in protocol.... as some it is painful while recording also.
are you testing any specific api's? or in the combination of any objects?.. if so, pls end an action of those transactions with end step network time delay/DOM loaded..
I'm using IE10 with LR11.52, it's working fine... You may need to check the action end options as suggested by ^Ram
I am using IE 11 and PC 12.01.. and I will try the suggested option.
ok cool.. pls try with one of these options...network and DOM, document loaded action completed..
Thanks, it looks relatively better now. But sometimes application itself is very slow, working with network team on it. How do you handle object identification? e.g. If X amount showing in account but now it has changed to Y and script starts failing. Is there any solid approach to deal with this kind of issues??
Go and check "animated delay" in general settings.if it is active with some time like 4000ms or some thing make it to "0"now there might be a chance to improve your replay time...and for the object identification,thinking that it is possible to go with correlations.
