Hi friends, I am going to run 1000 users in...
M
Manoj Kumar
Hi friends, I am going to run 1000 users in controller How to check which user is getting exactly failed. For eg-1 to 600 users are getting passed and reaming 400 users are getting failed means how to check it?
It doesnt matter which user is getting failed. What matters is the reason for failure which you can check in the Error logs.
You can check in the error r failed state in controller
You can insert a line containing parameter called VUser_ID into the script, but getting the Vuser id in case of troubleshooting is of not much use. As mentinoed by Harish Raj the reason for error matters,
