loadrunner Hi All, Is anyone having solution for session...
Rohith Kumar
Hi All, Is anyone having solution for session clearance for citrix protocol. Like server side settings or somthing else. Instead of doing manual clearance of citrix application.
It's been a little while since I've done this but I recall that there is a setting on the server that you should enable in your test system that forces a new session every time you connect a new vuser. I am pretty sure it is mentioned in the protocol guide for Citrix vusers. Have a look there.
