loadrunner Hi All- I recorded script with LR 12.2 ver...
Aparna Appu
Hi All- I recorded script with LR 12.2 ver using IE11 browser. Once am done with script recording, I was unable to move further . Either I could not able to click on any button or close vugen window even. Application gets freeze up. Again i need to go to task manager and need to close the application. Can some one help me on this ? Did anyone faced as such? Regards Aparna
Hey Aparna, try checking with the dev team regarding the compatible browsers/versions to run the application. This happened to me when I was using IE 6 instead of IE 8 couple of years back.
Hi Aparna, uncheck the rules scan and correlation scan in recording options before start recording, it might work
