loadrunner Hi All, After completing script execution in...
Ragul Gupta
Hi All, After completing script execution in performance center is it required for COLLATE button to be enabled. Can anyone tell me admin related or other setting for collating results. From below screenshot you can find the issue. Can any one provide me performance center end to end configuration and implementation realted documents and links. Thanks in advance Hi All, After completing script execution in performance center is it required for COLLATE button to be enabled. Can anyone tell me admin related or other setting for collating results. From below screenshot you can find the issue. Can any one provide me performance center end to end configuration and implementation realted documents and links. Thanks in advance
Hi Sagar Aggarwal... Thanks for quick response. When i ahve clicked on Analysis button below error has occured.I am providing screenshot of that. Please let me know one more thing will collate button will be in enabled mood or it need to be enabled.
ok.. you can change the status of your results in PC admin, if you have access..I am not using PC so i cant attach screenshot...I hope, it will resolve the issue..
