loadrunner Hello, we are executing HTTP+Citrix multiprotocol scripts and are...
Ashwin Nair
Hello, we are executing HTTP+Citrix multiprotocol scripts and are facing a unique issue. Whenever the script encounters a ctrx_get_text() or ctrx_sync_on_text() command, the scripts stops executing and the application logs off automatically and the session is killed. We are using LR 12.00 and are testing against Xenapp 4.5. We have installed LR citrix agent for Xenapp 4.5 on the citrix server and we observed that the process ctrxagent.exe exits from the server when the script tries to execute a get text or sync on text command. Kindly advise.
