loadrunner Hello guys, is there a way to bring up the...
Ashwin Nair
Hello guys, is there a way to bring up the citrix window real time during a multi user run in Performance center. I'm able to bring it up on a controller using "-lr_citrix_vuser_view" on the command line. But for some reason the same command is not working on PC 12. Is this because PC is a web front end and and does not pull data from the citrix client on the remote load generator? Any help would be appreciated. Thanks.
