admin submitted a new resource:
Comparing Two Timestamps In Loadrunner - Working with timestamps in loadrunner
Read more about this resource...
Sometime you get into a situation where you need to compare time between two clicks or compare the current timestamp with a server retured value in loadrunner. In this tutorial we have illustrated how you can compare current timestamp with the time on which the tutorial was written.
Attached is a working sample loadrunner script which you can play as a example.
Loadrunner Code:
Code:Action() { // The "calendar time" structure has the following members struct tm...
