loadrunner Application type Client/ Server Build using...
Anaz Mohamed
Application type Client/ Server Build using Java Cobra Client / Client has its Jar deployed in Client where ever its required. Normally application is invoked via/ by an exe Tried the below Protocol Advisor -Java Vuser 1.Java vuser - Invoking an exe no response 2.Recording using winsock:- zero events recorded/ tried diffrent combination of options(by googling :zero events recorded) 3.cOMd/com- zero events recorded 4.Win 32 via web - zero events recorded 5.as external engine :-zero events recorded 6.Java record and replay :-zero events recorded 7. 8. 9. . . . Tried many other steps by googling, calling HP support all steps took to the same road "zero events recorded" How to get events recorded Java cobra client application (.exe) is the question. or How do i invoke it
Are you in the midst of a 64 bit/32 bit conflict? Vugen and its components are 32 bit. If your java installation is 64 bit then you will forever have recording conflicts. I recommend a 32 bit windows VM with 32 bit java and your app as a clean baseline environment
