C
Chandrakant Singh
Application Overview:- Application- Java based Web server - Apache App server - Jboss LoadRunner version :- 12.50 Loadrunner protocol used:- HTTP/HTML Browser emulation:- Simulate a new user on each iteration + Clear cache on each iteration Issue:- Response time of all transactions is < 5 seconds till 15 minutes after the ramp up (180 Vusers ~250 hits/second). Response time starts increasing exponentially after some time with the same user load in steady state. Observations :- 1. CPU and memory on both APP and web servers are under threshold 2. No issues observed with Heap utilization on App servers 3. Performance logs on App server shows that none of the transactions took more than a second ( almost every request was served in milliseconds) 4. All queries were processed in milliseconds on the DB end 5. Enabled MOD_STATUS on the Apache web servers and noticed that during the high response time most of the requests are in state "W" SENDING REPLY (Mode of operation) 6. At the time of high response time the issue is reproducible manually in the browser Note:- Login is in init and there are 3 web_url requests with lot of CSS, js and some image files in "EXTRARES" All your comments and suggestions to identify the bottleneck are welcome Thanks
