loadrunner Analysis 12.50 for Performance Center 12.50. Downloaded raw test...
Analysis 12.50 for Performance Center 12.50. Downloaded raw test results and loaded up all the graphs. I enabled web Page Diagnostics. When I go into that graph and right click on a transaction listed and select Web Page Diagnostics for "", Analysis crashes (window disappears) and I have to start over. This is a simple web script with a single transaction/web request. Is this a known bug for 12.50? I can recreate this at will. If I need to log a ticket and send in a copy of the raw results, I am happy to.
Hi Scott, We have not encountered this issue in LR 12.50, I tried on my results and it is ok, but this kind of bugs is result specific. Can you please open a ticket for this and attach your Raw Results? Thanks, Mikhail
Service Request 4653506217 has been registered. I have provided links tot he Raw Results and complete System Information on the machine being used. Thanks!
I have a verified work around. Go into the Analysis Tools/Options. Change the setting for the defaults. Change Results Collection Tab to be "Generate complete data only". Also, change the Database tab setting from Access 2000 to SQLite. I have requested that the defaults for Analysis tools/options be changed, but also a fix that handles the crash of the Analysis module to be gracefully handled with an error rather than have a crash with no warning. Hope this helps someone else.
Oh so you ran out of row space in Access then. Makes sense. Longer runs with lots of monitors and transaction names will do that. It was annoying and if I recall correctly that workaround was what we did on our controllers since no matter what you set in PC the controller ran your analysis. Data analysis machines only seemed to kick in for trending
